Wideband only for closed loop
dickamusmaxamus
Post by dickamusmaxamus »
Hey all.
I'm in the process of wiring up my car, and I was planning on using the AEM UGO 30 0300 as the sole AF sensor for the car.
I have the AEM wired up correctly, sensor ground to the sensor ground on the analog ground, sensor wire to the 0 position on the analog pinout.
Attached are the two pictures of my analog configuration. I'm able to read the AF on KPRO correctly, it reads in KPRO the same as it reads on the gauge, but I can't seem to get the wideband to go into closed loop, it's just grayed out as an option. Any suggestions? Do I absolutely need to have a stock narrowband to make closed-loop work?
dickamusmaxamus
Re: Wideband only for closed loop
Forgot to add, deets on the setup.
PND 02-04.
What calibration are you using? You need a PRB calibration to use the external wideband input
