Use R+ throttle torque values for Comfort valuse
Posted: Sat May 09, 2020 5:59 pm
by FrankBusch1966
Hi,
does this make sense:
Copy the hole R+ torque values to the comfort values for each gear?
Does this effect that R+ and comfort mode have the same throttle pedal/torque behaviour?
Thx
Frank
Re: Use R+ throttle torque values for Comfort valuse
Posted: Sun May 10, 2020 12:22 am
by Civicboi_fk2
Hi,
I asked the same a while back apparently it is not that simple.
I’m sure Hondata will confirm though
Posted: Sun May 10, 2020 1:55 pm
You can't copy the normal and +R torque tables. The ECU determines there is some sort of problem and things get jerky.
Posted: Tue May 12, 2020 1:17 pm
by FrankBusch1966
Means there is a signal range check in comfort mode by the ECU?
And the values in comfort mode in CivicR-2015-2.fpcal are close to the allowed signal range and therefore cannot be increased?
Thx
Frank
Posted: Tue May 12, 2020 4:02 pm
Something like that. You can change the torque values up to a point, but if you make them the same as sport the ECU does not like it.
Posted: Fri May 15, 2020 3:48 pm
by FrankBusch1966
Thx :)
