Page 1 of 2
Radiator Fan always on
Posted: Thu May 07, 2020 12:26 pm
by OverRev
I have intake, intercooler, DP, full exhaust, was running 91 Oct, DP, intercooler map well for a couple weeks on my 2019 FK8. After I installed PRL Ti intake piupe and FlexFuel kit, I flashed the calibration to enable ethanol ready from ECT2, ethanol content, and the radiator fan is always on, like 5 sec after I started the car or ign on, checked radiator fan setting the on/off temp looks fine. Anyone have an idea how to fix this?
Re: Radiator Fan always on
Posted: Thu May 07, 2020 12:54 pm
Post your calibration as well as a datalog showing the issue.
Posted: Tue May 12, 2020 7:25 am
by OverRev
I tired 91 oct DP intercooler improved throttle response map with all 3 ethanol options checked, 2nd O2 disable checked, Reb hang and 7200 rev limit Checked, and I tried E0-E80 map with only ethanol input thru ECT2 enable, other 2 ethanol options not checked, the rest options same as above. Both map get the fan to turn in instantly. Checked PRL fuel fuel kit install and eventhing is fine.
Posted: Tue May 12, 2020 11:04 am
We do not need screenshots. We need the actual calibration as well as a datalog showing the issue.
Posted: Tue May 12, 2020 11:19 am
Is the flex fuel kit installed? Does it read ethanol content correctly?
Posted: Fri May 29, 2020 12:49 pm
by OverRev
Tired for 2 weeks, still no luck. How can I upload my calibration so you pros can check for me? I will download the lastest beta 3.5.9 and try again.
Posted: Fri May 29, 2020 12:56 pm
Save it to your hard drive, then attach it to your post using the attachment tab.
Posted: Fri May 29, 2020 1:24 pm
by OverRev
FlexFuel01.fpcal
Here is the calibration. before i tried 3.5.9 beta, I put ~10L of E85 in the car for the first time to make sure its reading properly (not easy to get E85 where I live so took me a month to finally got some) I drove the car around the block to mix the fuel and it showed ~16% ethanol on the screen. Oddly the radiator fan is not on anymore. does it mean i always have to run the car with certain % of ethanol?
Posted: Fri May 29, 2020 5:13 pm
Did we establish what ECU you have?
Posted: Sat May 30, 2020 1:53 am
by OverRev
Mine is 2019 Canadian Version
Posted: Sun May 31, 2020 7:39 am
Use 'send feedback to hondata' with everything plugged in and that will tell us.
Posted: Sun Jun 07, 2020 1:09 pm
We have reproduced this problem and are in the process of fixing this. It only occurs with ethanol free gas.
Posted: Wed Jun 10, 2020 2:32 am
by Semin1907
Thank you for the quick fix. Im going to try it ,now im downloading the update.
Thank you again.
Have a nice day
Posted: Fri Jul 10, 2020 7:22 pm
by OverRev
Correct, I have tried many different setting with the latest “non-beta” version, followed all the directions from Aston on FK8 review group but still no luck. The rad fan turns on full speed when Ethanol is lower then ~5%, and most high octane pump gas here in Canada is under 5% ethanol... so it’s like always on full speed in my case, not sure if it turns off at hwy speed.
Posted: Fri Jul 10, 2020 7:28 pm
by OverRev
Most importantly, I am getting my car dyno tuned. If the fixed is released after, can I have the fix applied to the tuned map? Or do I have to copy all the tables manually to a new base map?
