2016 FK2 Europe no Upload / Available maps
FrankBusch1966
Post by FrankBusch1966 »
Hi,
I just received the flashpro adapter from dealer and update the flashpro version to 30.04.2020, 3.570, Built 1521.
1.
I open calibration CivicR-2015-1.fpcal and try to upload to flashpro dadapter.
But I cant do this, because I receive mismatching vehicle typ MsgBox, see enclosed pi flashpro.jpg.
2.
Another question is, I can see only to basic maps for the FK2 Europe!?!
Where are the maps for stage 1, 2, 3 or mod exhaust xyz, octan 91/95/98 and so on stored?
Thx in Advance
Frank
Re: 2016 FK2 Europe no Upload / Available maps
There are not as many base calibrations for the FK2.
Have you plugged this FlashPro into your FK2 yet?
FrankBusch1966
Hi,
Going online with ECU, Jailbreak was done fine in just 5 Minutes.
Upload CivicR-2015-2.fpcal with mod 2+3 (Increase TC boost/pressure ratio limit)
Result was really very good! :)
I cant verify how much higher the HP/Torque is.
But I think it is a lot!
I wonder that I saw 1,9bar TC boost.
Is that normal?
Regards
Frank
1.8 bar peak boost would be typical.
FrankBusch1966
Thx, I will check this with enable datalogging
keikei288
Post by keikei288 »
Dear Sir
Original turbo parts can upload CivicR-2015-2.fpcal to ECU?
The pressure will be increase to 1.8bar?
i was change intake, inter cooler, oil cooler, radiator & exhaust pipe, Overall condition still stable?
Thank you sir.
Best Regards
Hondata User
have you tried it?
keikei288
Post by keikei288 »
Haven't tried yet, sir
You will have to try it.
