Hi,
I'm looking for a bit of help and haven't had any luck searching the web... While this isn't K-pro specifically related, I figured folks would know the answer to my question...
I am in the process of swapping a LS1 V8 into an S2000. I am working out the speedo circuit and the kit available is big $$$ and seems a bit much. I came across the K-tuned All-in-one VSS adapter that will boost a "low frequency" signal to the S2000s high frequency signal requirement. I pinged them and the person didn't seem to be much help...
basically I am looking to understand what the pulse per mile (PPM) signal for the Honda Low Frequency VSS is to compare it against the LS VSS PPM and what I would have to do to push that signal up in the LS PCM (I can push it to 131k PPM but the S2k cluster needs 160k PPM)
Thanks in advance!
Low Freq. VSS Signal Pulse
SilverS2kV8
1 post
• Page 1 of 1
Jump to
- General
- ↳ Hondata News
- ↳ Applications
- ↳ Non-Hondata
- s100/s200/s300
- ↳ s300 / SManager
- ↳ S300 Calibrations
- ↳ SManager Display Templates
- ↳ s100/s200
- ↳ Romeditor 4 Software
- ↳ HondaLogger Software
- ↳ Coil Pack Retrofit
- K-Series
- ↳ K-Pro / KManager
- ↳ K-Pro Calibrations
- ↳ KManager Display Templates
- ↳ K-Series Reflash
- FlashPro
- ↳ FlashPro Manager
- ↳ FlashPro Calibrations
- ↳ Accord 2008+ FlashPro
- ↳ Civic Si 2006-2011 Americas
- ↳ Civic Si 2012-2015 US/Canadian / 2013+ ILX
- ↳ Civic Type R 2006-2010 Japanese FD2
- ↳ Civic Type R 2007-2011 European FN2
- ↳ Civic Type R 2015+
- ↳ Civic 2016+ 1.5 Turbo Americas/Asia
- ↳ CRV 2017+
- ↳ CR-Z 2010-2012 US/Europe/Asia
- ↳ Fit 2007-2008
- ↳ RDX 2007-2012
- ↳ S2000 2006-2009 Americas/Europe/Asia
- ↳ TL 2007-2008
- ↳ TSX 2004-2014
- Traction Control
- ↳ General / Traction Control Manager Software
- ↳ Traction Control with S300
- ↳ Traction Control with KPro
- ↳ Traction Control with FlashPro
- Bluetooth Mobile Apps
- ↳ Hondata Mobile
