Error code P0101 keeps popping up
AC_FK8
Post by AC_FK8 »
Hi this error code keeps popping up even if I checked off remove error code p0101 and p0103. I cleaned my MAF sensor and checked intake and everything. I’m running 91 octane Full race Bolt ons basemap. I noticed this error code pops up when I don’t choose the intake option for AFM to read the same as stock. Is this the cause why this error code pops up? Has popped up on me 3 separate times already
2018 Honda Civic Type R
My mods are
PRL FMIC
K&N drop in filter
3” FP
3” Exhaust
Hondata Flashpro
Re: Error code P0101 keeps popping up
Why are you using a full race calibration when you do not have the parts needed for that calibration?
Do you have a Full Race intake?
AC_FK8
Post by AC_FK8 »
I know I probably shouldn’t be running this calibration. I tried the 91 octane with IC and DP with improved throttle response. My car just feels sluggish running that preset tune. I just purchased the PRL HVI stage 2 intake system and it’s on the way.
hozay
Post by hozay »
We’re you able to fix the problem? I’m dealing with the same issue
HowardFBeale
Post by HowardFBeale »
Me too. Im removing the p0101 and p0103 correction mod right now. I have the hondata maf so im hoping i keep getting this code because i dont need the mod.
HowardFBeale
What is your st and lt fuel trim reading? Mine was st -8-10 and lt around -15-18. Flash is done and its reading 0 on both but im assuming the ecm is now learning the mixture.
