Hi,
I am having IAT incorrect readings.
Currently all 4 PLX MODULES connected as follows,
have 4 plx modules connected to Hondata ecu.
1 PLX lamda module sending signal to ecu via analogue, and also sending power and signal to DM6 gauge
1 PLX water temp module sending 2 signals to ecu via digital
2 air temp modules sending 2 signals to ecu via 2 analogue signals
All 4 modules getting 12v ignition collectively
All 4 modules getting earth directly from ecu collectively
Problem as follows,
Lambda reading 100%
Water temp reading 100%
2 air temps under reading by around 50 percent. Hondata software has calibration settings to adjust it, but when using the plx preset values in the software , it is said in the software that adjusting and values means there is a ground problem.
So I've been trying to remedy the ground issue.
I am collectively grounding to E4 SG3.
Your site says to ground it there for all air temp sensors. But should I exclude other sensors from this batch?
And your help menus says the 2 black analogue wires are ground. But doesnt say its input or output grounds. Can I use it to ground at least the 2 air temps? Maybe separating my air temps from everything else will fix this?
Multiple PLX sensors
Jump to
- General
- ↳ Hondata News
- ↳ Applications
- ↳ Non-Hondata
- s100/s200/s300
- ↳ s300 / SManager
- ↳ S300 Calibrations
- ↳ SManager Display Templates
- ↳ s100/s200
- ↳ Romeditor 4 Software
- ↳ HondaLogger Software
- ↳ Coil Pack Retrofit
- K-Series
- ↳ K-Pro / KManager
- ↳ K-Pro Calibrations
- ↳ KManager Display Templates
- ↳ K-Series Reflash
- FlashPro
- ↳ FlashPro Manager
- ↳ FlashPro Calibrations
- ↳ Accord 2008+ FlashPro
- ↳ Civic Si 2006-2011 Americas
- ↳ Civic Si 2012-2015 US/Canadian / 2013+ ILX
- ↳ Civic Type R 2006-2010 Japanese FD2
- ↳ Civic Type R 2007-2011 European FN2
- ↳ Civic Type R 2015+
- ↳ Civic 2016+ 1.5 Turbo Americas/Asia
- ↳ CRV 2017+
- ↳ CR-Z 2010-2012 US/Europe/Asia
- ↳ Fit 2007-2008
- ↳ RDX 2007-2012
- ↳ S2000 2006-2009 Americas/Europe/Asia
- ↳ TL 2007-2008
- ↳ TSX 2004-2014
- Traction Control
- ↳ General / Traction Control Manager Software
- ↳ Traction Control with S300
- ↳ Traction Control with KPro
- ↳ Traction Control with FlashPro
- Bluetooth Mobile Apps
- ↳ Hondata Mobile
