2012 SI Calibration Help
Rmart980
Post by Rmart980 »
I have a Taketa intake full race catted exhaust and full race cat back exhaust. I'm running the MAF base right now. It feels pretty good but got a P0172 the other day. I don't know how to tune any of it.
EFICU
Re: 2012 SI Calibration Help
Post by EFICU »
Do you have any datalogs we can look at showing the issue?
Which calibration are you running right now?
Rmart980
Post by Rmart980 »
This data log is on the SRI,full exhaust base....I put this base on this morning and drove to get food. the mods are basically what I have but this was the worst the car has ran yet....
EFICU
Post by EFICU »
Yeah it's definitely running rich. So the car drove worse with this map in it than it did with the one you were driving on and got the CEL code?
I will attach a file below for you to start on. This is just a 0* cam angle map to see how things look. It may seem a little sluggish at first because there is no cam angle in it. I just want to try and get the fueling close before we make a bunch of changes. Take this one for a drive just like your datalog you posted, same driving style, then post it on here so I can look at it. Also Rmart, please fill out the customer info section under "calibration" for me so I have your information for my records.
This file is for Rmart to start on and is only tuned for the 0* cam angle and will only utilize the 0* cam angle for anyone who downloads it. Don't use this file unless you plan to tune each cam angle individually starting with the 0* cam angle.
Rmart980.SD.Rev01.2 Test(0 cam only).fpcal
Rmart980
Post by Rmart980 »
ok I will give it a try and post back...I was on the MAF tune when the cel came on. I had been running that tune for a week. but thought to try out the other this morning to see what it did.
Rmart980
Post by Rmart980 »
ok here it is, I had 101 knocks on the app when I did that data log
EFICU
Post by EFICU »
No problem. We'll get rid of the knocks, they were all clumped in two main areas so I cleaned those up for you. Make sure you fill out the calibration section in this next tune and repost it with a new datalog so I have more information.
Here is the next one for you.
Rmart980.SD.Rev02.fpcal
Rmart980
Post by Rmart980 »
This is what we got..feeling better, it feels like it has a slight bog when vtec hits. I emailed you back the info you requested. Thanks
EFICU
Post by EFICU »
Here is the next one. Now you will be on the 15* cam angle for this one. Try to make the datalogs 20 minutes or so from here on out so we can build up quite a bit of data in each datalog. Same driving style though.
Rmart980.SD.Rev03 (15cam).fpcal
Rmart980
Post by Rmart980 »
alright got a good 30mins on this one.
EFICU
Post by EFICU »
Here is the next one. Now on the 30* cam, vtec will be at 5500 on this next one. Just moving it around to tune around the vtec engagement.
Rmart980.SD.Rev04 (30cam)(Vtec5500).fpcal
Rmart980
Post by Rmart980 »
ok, that was feeling the best yet!
Rmart980
Post by Rmart980 »
didn't add in the last post
EFICU
Post by EFICU »
Here is the next one, vtec is at 3800 now, still on the 30* cam.
Rmart980.SD.Rev05 (30cam)(Vtec3800).fpcal
Rmart980
Post by Rmart980 »
Good morning. This is what we got on that one. Running great so far!!
