Hi guys! I need help via "vtec button "!
Pokemon123
Post by Pokemon123 »
Hello my friends! I just have a idea, can you told me, is it OK?
So, in my turbo EK b20/b18 I don't have vtec pressure switch, so vtec is activated from the ECU on 4600 rpm. But I have a button on D6 VTP (vtec pressure)...is it possible to do something like "vtec button", If it "on" I have vtec on 4600, if it "off" there is no vtec.... I think if I activate check button in sManager "vtec oil pressure switch enabled" it will work? Or not? And if it right, I need delete check box from "VTEC Enabled "?
Tnx for watching >)
Re: Hi guys! I need help via "vtec button "!
Why would you want to turn VTEC off and on manually?
Pokemon123
My turbo civic is a daily car. I driving on 1.1 bar without vtec and this is good + engine have more resources. But sometimes I want to drive with vtec, and it is so sad to take notebook in car, just to check box "enable vtec " )
There is no reason to do this. VTEC should be activated by the ECU and when properly tuned you should never have to turn it off and on manually.
