Kpro map data log.
Posted: Sat Mar 28, 2020 11:32 pm
by JerryFran
Hi,
would it be possible for someone to have a look at this map and let me know if it would be possible to drive just under 2 hrs to a tuner safely. If not can I get an idea of what I need to change.
Thanks.
Re: Kpro map data log.
Posted: Mon Mar 30, 2020 11:22 am
You should discuss this with your tuner as he should be able to look at this for you. Since I cannot see a wideband reading there is know way of knowing what the fueling is like.
Posted: Tue Mar 31, 2020 1:03 am
by JerryFran
Thanks,
I have spoken to them about it and due to COVID19 they are close till the end of April. however I have used a different Cal due to having to take the car for an MOT which failed on emissions. I turned on auto log which recorded every thing thing.
When there is not A/F its reading on the dash 9.7 but on my computer it in setup its from 10-20 readings.
Setup.
K20A2 EP3
T25 Ebay turbo
Godspeed wastegate
Mac 4 port Boost Sol
Jerry
