GM Flex Sensor Location and Coolant Pressure Sensors
b.sanford84
Post by b.sanford84 »
Flex sensor location Curious if there is a preferred location for the flex sensor? I dont want it in the bay, I was thinking of mounting it closer to the tank. Would this be ok as long as its in the return line? flex fuel, says 9-18v, but can I power this off b2/d19 or should I get power elsewhere?
Coolant pressure sensors Im considering running of these as well. but, not really sure the optimal location for it. I thought to keep it out of the way, I could weld a bung to my water crossover tube and mount it there.
Wiring analog wiring , it states to power the sensors from the B2 and D19, at what point would there too many sensors (theyre all 0-150 psi 0-5v transducers) on those two locations? I plan on having oil pressure, fuel pressure & coolant temp is that too many to tap off b2/d19
Re: GM Flex Sensor Location and Coolant Pressure Sensors
I would recommend that you install this in the engine bay. I would recommend that you use switched power from the fuse box.
I'm not sure why you want to measure coolant pressure. Coolant temp should be adequate.
What version s300 do you have?
Coolant pressure can show when the cylinder head is starting to lift. If you put the sensor between the engine and radiator you'll get a big rise in pressure with rpm (from memory up to 45 lbs). Never tried any other locations.
b.sanford84
I have version 3.
Why do you suggest the engine bay when the OEM puts it on the frame rail in their trucks?
DaX
Post by DaX »
Just as a data point, I have my flex fuel sensor mounted just below my FPR - see picture below. I'm running my flex fuel sensor off a 12V subpanel I installed that also powers my additional gauges, boost solenoid, and wideband.
The only person I've personally seen running a coolant pressure sensor is AZ_CIVIC on Honda-Tech, and his sensor is mounted directly into the head under the distributor...maybe repurposing the coolant temp gauge port?
b.sanford84
old post i know.
I got my flex sensor installed and running. for those who are curious or may face the same issue I did.
I got power from the fusebox, grounded to thermostat housing and ran signal to AI0. I had it grounded to chassis ground in the beginning, and it wouldnt work. I decided to test grounding to thermostat housing and it started working. I need to test my e85 and compare to the reading I get but for now its functional.
