Page 1 of 2
V4 Rev limiter issues
Posted: Sat Feb 22, 2020 1:16 am
by DC5808R
Hello, I have weird rev limiter issue going on with the v4 version 4.4.2.0...
My upgrade was done with you guys which is from kpro sn # 3219
ecu sn # is 2062-100437 pnd-a01
kpro4 sn #48768
Anyways my issue is that I will hit limiter which is set at 9400rpm in 1st gear but in 2nd gear it will cut me short at around 8200-8500rpms
here is my datalog and kal
My car is a fully built turbo rsx and we have checked all sensors and gapped plugs down to 0.18 with afr being spot on during the weird rev cut...
I have proper ground setup as well. Please let me know if you need a bit more info or is seeing something I'm not seeing that is causing this weird rev limit cut/issue
Re: V4 Rev limiter issues
Posted: Sat Feb 22, 2020 9:08 pm
by DC5808R
So I did a sensor overlay log on the rev limiter active overlay and it shows the sensor activating and deactivating at different rpms besides the actual rev limiter which is at 9400rpm. My question is if this is normal? I thought the rev limiter would only activate at the actual rev limit that it is set to?
Posted: Sun Feb 23, 2020 5:29 pm
by Jakermac
Is it possible that what you are experiencing is spark blow out? What boost pressures are you running and what spark plug gap are you running?
Posted: Sun Feb 23, 2020 9:19 pm
by DC5808R
Highly unlikely, as posted above spark plugs are ngk bkr8eix gapped down to .018 brand new. When getting cut, boost is around 15 - 20psi... The rev limiter activates at weird rpms besides 1st gear it, it will let me go up to the rev limit which is at 9400rpms... Car drives perfectly fine when not in boost or in 1st gear going into boost, but in 2nd gear or other gears, car rev limiter will activate at weird rpms...I believe this is a software issue as me and my tuner is stumped to why it is doing this...
Posted: Mon Feb 24, 2020 11:57 am
Have you tried disabling the lean protection?
Posted: Mon Feb 24, 2020 8:11 pm
by DC5808R
Spunkster wrote: Mon Feb 24, 2020 11:57 am Have you tried disabling the lean protection?
Yes, we have...It's definitely not hitting a lean cut.
Posted: Tue Feb 25, 2020 10:37 am
Post a datalog with that disabled and post the calibration used for that datalog.
Posted: Tue Feb 25, 2020 9:11 pm
by DC5808R
Spunkster wrote: Tue Feb 25, 2020 10:37 am Post a datalog with that disabled and post the calibration used for that datalog.
Sure thing. Here you go...
Posted: Wed Feb 26, 2020 11:59 am
Try going to the online menu and erase the ECU, then key off when it is finished, close the program and reopen it and reupload the calibration.
Posted: Wed Feb 26, 2020 11:16 pm
by DC5808R
Spunkster wrote: Wed Feb 26, 2020 11:59 am Try going to the online menu and erase the ECU, then key off when it is finished, close the program and reopen it and reupload the calibration.
Will do!
Posted: Thu Feb 27, 2020 11:08 am
by DC5808R
Here you go...
Posted: Thu Feb 27, 2020 12:29 pm
Try creating a new calibration from the new calibration menu and see if you still have these rev limits. It appears you may have a corrupt calibration.
Posted: Thu Feb 27, 2020 12:32 pm
by DC5808R
Spunkster wrote: Thu Feb 27, 2020 12:29 pm Try creating a new calibration from the new calibration menu and see if you still have these rev limits. It appears you may have a corrupt calibration.
Ok, will do and report back!
Posted: Thu Feb 27, 2020 9:55 pm
by DC5808R
Here you go...Same issue with a fresh new calibration.
Posted: Fri Feb 28, 2020 12:41 pm
I would recommend the you try this ECU on a different vehicle using their calibration and see if it has a similar issue.
