Eld and fuel metering check engine light
Undefined4door
Post by Undefined4door »
To make a long story short I have a plx wideband hooked and using the eld input as suggested, set it up in flashpro. I have been getting the eld code for awhile p1298. I'm also getting a code for fuel metering too rich p0172. Is there anything in setting I could disable for this?
Re: Eld and fuel metering check engine light
What vehicle are you referring to?
Undefined4door
2005 acura tsx 6spd sprry
Why not use B12 or B22 instead of the ELD for the sideband input?
Undefined4door
Most people used the eld input as does the wideband install recommends the eld input but if b12 can be used I'll just switch it
Undefined4door
Any thoughts on the p0172 code cause?
The ECU does not use the aftermarket wideband signal to make any adjustments or throw errors. If it is saying it is too rich then you will need to lean it out.
