Flash pro modification table question
Posted: Sun Feb 09, 2020 1:44 pm
by 1chicoirk
I have been playing around with flash pro software while awaiting the interface, I selected the 3# boost for cvt calibration for my 2017 Civic, and this modification window pops up with several check boxes ie… Boost-optimizes turbo response, Throttle-improved response, throttle-disable VSA, throttle-disable rev hang. My question is, do I need to check the boxes for throttle response and boost, I thought those items were part of the original Hondata calibration, also not sure about the disable VSA, and disable rev hang, what they are and should they be selected.
Thanks for any help or insight
Re: Flash pro modification table question
Posted: Sun Feb 09, 2020 9:57 pm
by EFICU
In the file, you will need to click on the boxes in which you want to add to the tune.
Is the car stock, or do you have modifications?
I wouldn't disable the VSA, that you should keep doing manually. VSA is essentially the traction control system.
I would disable the rev hang feature. Rev hang means the throttle stays open for a little bit even after you remove your foot from the pedal. Most people like this function shut off.
Some people like the increased throttle response, and others don't, so that one you might try and see if you like it better with or without.
Optimized turbo response would probably be one you would want checked.
Once you get it running, post a datalog and your calibration as the MAF will most likely need some scaling. We can look it over and help you out with getting the fueling dialed for you.
Posted: Mon Feb 10, 2020 10:58 am
by 1chicoirk
Thanks so much for your informative response, I am not real tech savvy, but will try and do a data log and post it.
Thanks again
