Car wont start after Re flashing
Posted: Sat Feb 01, 2020 5:38 am
My civic hatchback 1.5 CVT won't start after a reflash, I have reflashed it before and it worked but after testing it out and noticing it fails to change gears I wanted to return it to stock to put it on the +3 psi option.
When I press down on the brake and press the start button it does not start but the dash does light up. I'm not sure if I should keep trying to reflash to stock.
This is the error code I get.
The last Flashpro upload failed.
Failure information : code 0x05 Step 16 Address
0x0FFF00
Explanation: The ECU stopped responding while
reflashing. Check OBDII connector pins
0x0FFF00
