Base target lambda overlay on WOT compensation tables
latelifecrisis
Post by latelifecrisis »
I am running Flashpro 3.4.4.0. I understand how the current WOT compensation tables work. I have WOT based on MAP table enabled so with Flashpro uses the low and high cam WOT tables when I exceed the specified MAP based on engine rpm.
I also understand the purpose of the target lambda overlay. Unfortunatley, this overlay is only based on engine load (MAP) without factoring in engine rpm.
What would be very helpful is to have the ability to have the target lambda overlay values (especially delta lambda) be based on the AFR values that are contained in the low and high cam WOT compensation tables. This would make the process of tuning the AFR values in the low and high cam fuel tables MUCH easier.
Is this a change that could be made to greatly simplify the fuel AFR tuning process whenever the WOT tables are used by the ECU?
Re: Base target lambda overlay on WOT compensation tables
What vehicle? Why use an old version of the software?
