Fuel table and injector size trouble
TheDonsSI
Post by TheDonsSI »
I have a Kraftwerks supercharged k20z3. Grams 1000cc injectors with aeromotive fpr. 340lph fuel pump for ethanol. I have the fpr boost referenced. At idle I’m reading right at 46 lbs fuel pressure. Revving you will see a little over 60. I don’t have a fuel pressure problem obviously. I’m seeing leaning in my fuel tables at about 3 lbs of boost consistently. Low cam and high cam settings. When I increase the fuel tables values it’s almost like the leaning gets worse. I’m using 40% ethanol and there’s no reason for the fuel system to be maxed out with this setup. My injector duty cycle only sees a high of 57% at WOT. HELP!!!!
EFICU
Re: Fuel table and injector size trouble
Post by EFICU »
Do you have any datalogs you can post that show the issue, and can you post the calibration you're on so we can look it over?
