Engine : B16a2 block/ stock B16a head
Arp everything inside the block.
81.5mm 11:8:1 high comp ctr pistons, bored, honed,
golden eagle block gaurd
acl bearings Hasting rings,
decked,
eagle h beam rods resurfaced
arp head studs and bolts nuts washers balanced and polished crank
Oem type r water and oil pump
Speed factory titanium intake studs
Skunk 2 pro intake
Skunk 2 72m throttle body
Skunk 2 alpha headers
Spoon spark plug wires
Spoon oil pan
Spoon drain plug
Aem complete fuel rail ( gauge and regulator)
255 walbro fuel pump.
I’m looking for a good base map to run or a something I can use currently on stock p30 map on Hondata ( doesn’t like to start up in the cold weather unless I give it gas while turning the key ) thanks in advance
Semi built b16a2 need help
francesray
- Contact:
Re: Semi built b16a2 need help
I wonder the same, any idea?
