Car not starting after flashing tune
Posted: Sat Dec 21, 2019 2:55 pm
by ed_rod5
2018 Honda Civic type r - Hondata serial #: FP-CTR-FK8-351003
After installing the Sirimoto flex fuel kit, I am trying to flash the flex fuel kit tune. The tune uploads and Hondata software instructs to turn off the ignition. After that the program doesn’t show us that the tune was successful. I turn the car off then turn it back on and nothing. The dash is lit up with check engine light, tpms, etc. any help would be appreciated
Re: Car not starting after flashing tune
Posted: Sat Dec 21, 2019 3:12 pm
by ed_rod5
The messages on the display consist of rev match system problem and drive carefully systems initializing....
Posted: Sat Dec 21, 2019 10:25 pm
Please use the 'send feedback' function with the FlashPro plugged in and ignition on.
Then return the ECU to stock (not stock equivalent) and try that.
Posted: Mon Dec 23, 2019 10:07 am
by ed_rod5
I had a DTC. P0102. Turns out had a 5A on the flexfuel jumper instead of 10A connected to the under dash ACG slot. The car started right up. Although the ethanol gauge does not work anymore. Thank you for your time!!!
