ID1050x Injectors
Posted: Fri Dec 13, 2019 9:21 pm
by jgadell
Curious what everyone’s been using for ID1050X’s dead times. Tuned running cars not rough basemaps. Mine is tuned using ID1000 dead times supplied within s300 but curious if anyone is running different times.
Re: ID1050x Injectors
Posted: Sat Dec 14, 2019 9:36 am
by DaX
I'm running ID1000's and just use the preloaded dead times in Hondata, but Injector Dynamics has dead times for the 1050x listed on their site:
http://injectordynamics.com/injectors/id1050x/
Scroll to the bottom and click the tab that says "Slope & Offset vs. Pressure".
If you want to try to calculate your own dead times, HA Motorsports has an article on how to do it:
https://www.hamotorsports.com/how-to-se ... -time.html
Posted: Sat Dec 14, 2019 8:16 pm
by jgadell
Those dead times listed on ID’s site are way to low valued. My idle cells would be like 1. She’s idling and runs using the ID1000 dead times supplied via hondata (not what’s on ID’s site). Just curious more than anything
Posted: Sun Dec 29, 2019 8:41 am
by crluver123
jgadell wrote: Sat Dec 14, 2019 8:16 pm
If you are using ID1050x injectors, and the dead times provided by ID for the 1050x's are causing major issues for you, then you have major problems somewhere else in the tune. The dead times ID supplies are very close to perfect, usually requires a very
small amount of tweaking for AFR to be the same at running voltage and battery voltage (alt unplugged).
I use ID1050x's, and I'm a career tuner. The dead times in my personal car are below, and I spent several days in different weather conditions verifying they are the best possible: (first value is voltage, second value is dead time)
7.99 - 2.00
10.01 - 1.49
12.04 - 1.15
13.96 - 0.97
15.98 - 0.84
Posted: Mon Jan 06, 2020 5:21 pm
by rofeksos
crluver123 wrote: Sun Dec 29, 2019 8:41 am
7.99 - 2.00
10.01 - 1.49
12.04 - 1.15
13.96 - 0.97
15.98 - 0.84
I am running ID1050x as well and when I opened up my calibration to see the values I was using I noticed that my injector size is set to "1000" in the "Current injector size" field. Should I be using "1050" or "1065" as 1065 was the flow rate advertised on ID's site?
If I update the values of the dead time to the values that you're using as well as the value for "Current injector size" to either 1050/1065 would that affect my tune? I am currently using the ID1000 dead times from the quick select pop up menu.
Posted: Wed Jan 08, 2020 5:19 pm
If you aren't having any problems then leave things as they are.
Posted: Thu Jan 09, 2020 5:59 pm
by crluver123
rofeksos wrote: Mon Jan 06, 2020 5:21 pm
Yes, if you change the latencies to what I am using, it will have a MAJOR impact on the tune. You would need a complete re-tune afterwards.
Posted: Sun Jan 12, 2020 1:49 pm
by jgadell
7.99 - 2.00
10.01 - 1.49
12.04 - 1.15
13.96 - 0.97
15.98 - 0.84
any chance you can upload a picture of your fuel tables or such? my car runs fine and such as is using the ID1000 deadtimes. when i tried using ID's it was super rich and my fuel values were like 1 or something i cant recall at the moment.
Posted: Fri Jan 17, 2020 9:13 pm
by crluver123
jgadell wrote: Sun Jan 12, 2020 1:49 pm
1% duty cycle at idle is totally normal. And not to be confused with fuel table values.
At idle, I'm between 125 and 260 for fuel table values.
My fuel table would be pointless, as we have two completely different motors, and our temp compensations are likely different too
