Plx dm6 to prb kpro v4 ep3
Posted: Mon Dec 09, 2019 4:02 pm
by Saku123
Hi, just bought plx dm6 multigauge and lambda sensor.
I wonder how to connect it to ecu? I think that i take old lambdas off and put the car workin only with plx wideband.
Re: Plx dm6 to prb kpro v4 ep3
Posted: Mon Dec 09, 2019 5:29 pm
Do you want to run closed loop from the aftermarket wideband or do you just need it for datalogging?
Posted: Tue Dec 10, 2019 4:20 am
by Saku123
I want to run closed loop
Posted: Tue Dec 10, 2019 1:11 pm
You will have to wire the wideband signal into the analog input on the K-Pro board and then configure the analog input settings for your wideband. Then go to the closed loop settings and select the option to run on an external wideband.
Posted: Wed Dec 11, 2019 9:56 am
by fonzeka
Digital input works great as well, I've been running that for years now.
Posted: Fri Jan 10, 2020 11:29 am
by Saku123
Does anybody have did this? Im wondering how to do wiring job correctly.
Posted: Sat Jan 11, 2020 5:42 pm
by fonzeka
I+ and G on the kpro board connects to TX on the PLX module.
Posted: Mon Jan 13, 2020 3:03 pm
by Saku123
Thanks a lot. I Will test it soon
Posted: Wed Jan 15, 2020 4:53 am
by Saku123
Hi, i took my old lambda out and put plx in. I selected external wideband in k-manager options. But now it gives p1166 trouble code. (Primary O2-sensor heater)
What causes this?
Posted: Wed Jan 15, 2020 10:11 am
Try unchecking the enable sec O2, FTP, PA and ELD in the Misc section.
Posted: Wed Jul 08, 2020 5:17 am
by Saku123
Digital input did not work on my hondata with plx dm6, i think i will test analog input. Can someone tell what settings i have to select In k-manager?
Posted: Wed Jul 08, 2020 9:24 am
You just need to set the analog input to the PLX in the parameters for analog input.
