MAP scale when logging is weird
Posted: Fri Dec 06, 2019 8:50 pm
by DaX
I'm using SManager 2.7.5.0. Datalog was taken on 20-Nov-2019, so I'm not sure if that was before or after I updated to the latest SManager and I'm not sure if it would look like this in the previous version. Anyhow, the scale for MAP is from zero to a huge number (10^13!!) on the side of my logs, but the cursor shows the correct MAP value. If I go to Options > Sensors > MAP, the unit is set to "/psi and the range is from -29.92" minimum up to 30 psi maximum. It's not a big deal, but I just wanted to point it out to see if it's a bug or if I may have something set up wrong.
Re: MAP scale when logging is weird
Posted: Sat Dec 07, 2019 8:22 pm
by crluver123
Go to OPTIONS at the top, click SENSORS, select map sensor, check the min and max values
Posted: Sun Dec 08, 2019 5:13 pm
by DaX
Yep, I made sure that was set up correctly - 2nd to last sentence of the original post.
-29.92" minimum
30 psi maximum
I'll try to do a fresh log in the next few days and report back.
Posted: Mon Dec 09, 2019 10:16 am
If you go to the sensor list and double click the MAP what settings to you have it set to there?
Posted: Mon Dec 09, 2019 1:42 pm
by DaX
Posted: Mon Dec 09, 2019 5:36 pm
It is just a rounding error in the display and will have no effect on any readings or tuning. We will correct this in the next release.
Posted: Tue Dec 10, 2019 1:46 pm
by DaX
Sounds good, Spunkster.
