Stock intake and return to stock flash
Posted: Sat Oct 26, 2019 6:54 am
Can somebody help me take a look at my datalog.
This is with stock intake and "return to stock" flash, and unlock from vehicle.
After return to stock and unlock vehicle, i was curious how the stock map perform. So i did a datalog.
Surprisingly the STFT always at negative. At idle the STFT will be at negative -10% to -16%.
Before that i was using K&N typhoon open pod intake kit and a custom tune 22psi and i never have such high negative STFT.
And also my AFR is so rich it deeps down to ~9 from 3000 rpm and i never hit max boost of 16.5psi as advertised by Honda.
Is the "RTS" flash exactly return to factory map or hondata's version of stock map that try as close as factory map?
