street tuning not sure if im understanding correctly questions
Posted: Fri Oct 04, 2019 11:27 am
hi im trying to do basic street tune and understand how it works
lsvtec turbo forge rod piston combo stock head b16
innovate mtx-l wide band
theres no real videos on step by step how to tune just parts from google youtube anyways does this sound about right?
I load a p72 stock gsr basemap
set the injector size
set map sensor
set wideband settings (match the hondata laptop reading smanager to the gauge accurately)
set physical ignition timing to 16btdc
setup lambda settings 14.7:1 / 13.5/ 11.5 area (user preference)
start car
make sure no cel whatsoever
now tune target afr low fuel
then tune target afr low speed ignition
now tune target afr high fuel
then tune target afr high speed ignition
is there anything im missing?
I just want to street tune it to be able to learn and to be able to drive it to the tuner (40 miles away)
set map sensor
start car
