What do the negative G/S numbers stand for ?
Civic 2016+ 1.5 Turbo
alex_hockey69
Post by alex_hockey69 »
When tunning your MAP table . What do the negative G/S numbers stand for ?
Re: What do the negative G/S numbers stand for ?
Nothing. That's just how Honda has set up the AFM table. If the sensor has an output in the negative range of the table then there is a sensor fault, so the negative numbers are not used.
alex_hockey69
Hondata wrote: Sun Sep 29, 2019 8:39 am Nothing. That's just how Honda has set up the AFM table. If the sensor has an output in the negative range of the table then there is a sensor fault, so the negative numbers are not used.
Oh ok makes sense. So when tuning the AFM table we should not touch the negative-g numbers
