Running E27, How do adjust tuning?
Posted: Thu Sep 19, 2019 5:38 pm
by turboroe
So, by law, here in Brazil our regular gas is E27 (27% ethanol added) and premium gas (which is found almost nowhere and costs usually 50% more) is E25.
I was wondering what kind of adjustments should be taken into account when tuning for this fuel, parting from hondata´s basemap calibrations?
By what I understand, our gas should have more octanes, higher compressibility, and stoichiometric value lower than regular gas.
SO where does this take part in the tuning? should I aim for lower AFR?
Can I use higher boost pressures?
Does the S.TRIM compensate for this ?
Re: Running E27, How do adjust tuning?
Posted: Thu Sep 19, 2019 5:49 pm
by turboroe
Our regular gas (e27) has 87 IAD/91 RON despite the ethanol addition.
Posted: Fri Sep 20, 2019 8:46 am
What ecu/binary do you have? It it was designed for E27 then it will work. The knock control should take care of adjusting the ignition for you.
Posted: Fri Sep 20, 2019 9:01 am
by turboroe
Mine is 37820-5AA-M61
I'm pretty sure it was designed for this gas, but I was thinking if the hondata reflash doesn't mess with the E27 factory calibration.
Anyway, I am reading about fine tuning for my specific car, and from what I gathered I should do the following, on top of the basemap calibration:
1. closed loop AFM calibration
2. Wot a/f adjustment fine tuning
3. Knock elimination by retarding on frequent knock map portions
Is this it, or should I do anything else to have a perfect setup for my car with everything stock?
Much appreciate your help! :)
