Page 1 of 2
can anyone help me with my AFM
Posted: Wed Sep 18, 2019 4:46 pm
by alex_hockey69
i am not 100% sure if i am tunning my AFM tables correctly . not sure if i am changing the right G/S numbers. would really appreciate some help.
2017 civic si coupe running +6psi FTS with a K&N short ram intake
Re: can anyone help me with my AFM
Posted: Wed Sep 18, 2019 7:11 pm
by NikkoPH
Hey Alex,
I would start by adjusting your AFM by +3 on 0-10 g/s and +5 on 10.01-60 g/s
Upload, datalog and fine tune it by adjusting into small g/s clusters.
Posted: Wed Sep 18, 2019 7:25 pm
by alex_hockey69
for example i start with 0.52 all the way to 10... +3
Posted: Thu Sep 19, 2019 7:11 am
by NikkoPH
Yes, highlight all cell on that range and adjust by +3.
Posted: Thu Sep 19, 2019 7:43 am
by alex_hockey69
Thank you I did a data log this morning I will post it later on today. I am still unsure how to read the graph should I be looking at the line in the middle that varies or should I be looking at the red spots? I'm not too sure what you mean by fine tune it by adjusting into small g/s clusters.
Posted: Thu Sep 19, 2019 8:00 am
by alex_hockey69
NikkoPH wrote: Thu Sep 19, 2019 7:11 am Yes, highlight all cell on that range and adjust by +3.
Posted: Thu Sep 19, 2019 8:15 am
by gtfrede07
To clarify adjust by percent (ie: +3%). Usually make half the desired change and retest.
Posted: Thu Sep 19, 2019 9:10 am
by NikkoPH
The +3 is rough estimate of the average you need to trim in the AFM from the given range. See how the car reacts to this and re test. From there you may calibrate your AFM by smaller clusters.
Posted: Thu Sep 19, 2019 9:21 am
by alex_hockey69
NikkoPH wrote: Thu Sep 19, 2019 9:10 am The +3 is rough estimate of the average you need to trim in the AFM from the given range. See how the car reacts to this and re test. From there you may calibrate your AFM by smaller clusters.
Posted: Thu Sep 19, 2019 10:00 am
by gtfrede07
The blue line represents the median average of all the little red marks. If it is a strong cluster of a bunch of data points use the line reference. If its sporadic little ones (unless a small cluster are together) then use your best judgement. Essentially the more data points make the blue line more accurate of a suggestion.
Posted: Thu Sep 19, 2019 10:09 am
by NikkoPH
Dont look at the red dots or you will go crazy lol!
Posted: Fri Sep 20, 2019 2:07 pm
by alex_hockey69
NikkoPH wrote: Thu Sep 19, 2019 10:09 am Dont look at the red dots or you will go crazy lol!
the drive feels better but my LTFT is high now
Posted: Sat Sep 21, 2019 8:25 am
by NikkoPH
You are still running lean. Adjust 0 g/s - 10 g/s by +3 and 10.01 g/s onwards by +4.
Goodluck!
Posted: Sat Sep 21, 2019 10:04 am
by alex_hockey69
NikkoPH wrote: Sat Sep 21, 2019 8:25 am You are still running lean. Adjust 0 g/s - 10 g/s by +3 and 10.01 g/s onwards by +4.
Goodluck!
I'm trying to understand if I am still running lean why is my LTFT showing I am running rich .
Posted: Sat Sep 21, 2019 10:37 am
by alex_hockey69
Goodluck!
following the blue line from g/s 0-about 14 showing i am running rich about -3
