Wideband goes rich right after letting off throttle
Posted: Tue Sep 17, 2019 8:34 am
by G. Wiffington
Is it common for the wideband to go from cruising at 14.0s then when you let off of the throttle it goes rich like into 12s?
Re: Wideband goes rich right after letting off throttle
Posted: Tue Sep 17, 2019 9:33 am
No it should not. When decelerating it should go fully lean.
Posted: Thu Sep 19, 2019 10:12 am
by G. Wiffington
Sorry I should have been more specific.
Yes it does end up going to full lean with no throttle but just right as I lift my
foot from the pedal if I was just cruising, the wideband will go rich for a second
then all the way lean like it should.
I was trying to chase the spot on the map, just thinking it was really rich on the
lowest fuel lines when looking in 2D. But, even then when pull a bit of fuel in that
area it still will get rich right after I left off throttle.
Posted: Thu Sep 19, 2019 1:54 pm
I wouldn't worry too much about this as this sounds pretty normal.
Posted: Thu Sep 19, 2019 2:06 pm
by frederic1973
what is your version ?
Posted: Fri Sep 20, 2019 11:49 am
by G. Wiffington
Okay thanks Spunkster.
I will have to check when I get home on the Version, I do not have my laptop with me.
I am pretty sure it is up to date though.
I have had this going on for like 2 years or so. Never really worried about it I was just
curious if anyone gets the same thing.
Posted: Fri Sep 20, 2019 1:31 pm
by DaX
I'm using a PLX wideband, and I also get a blip towards rich before going to "AIR" when letting off the throttle. Just sharing as a data point.
Posted: Wed Sep 25, 2019 7:24 pm
by crluver123
this is fairly normal. It's basically the opposite of tip-in enrichment. Tip-in is when you quickly add throttle, the engine will naturally have a lean spike, and that's why tip-in enrichment adds a little extra burst of fuel for when you quickly add throttle. Quickly reducing throttle has the opposite effect; a quick rich spike, but there is no way to adjust for that and really no need to adjust for it either because it is not dangerous for the motor.
Posted: Fri Sep 27, 2019 11:38 am
by G. Wiffington
Thanks guys!!
I am glad I am not the only one.
