NA b20vtec tune availble??
Posted: Thu Nov 07, 2002 1:56 pm
by no mods
new to this board.. didn't know if there is a NA b20vtec tune availible yet..
hondata-4
pr3- b20vtec
skunk2 stg 1 cams IHE
victor X man.
Posted: Thu Nov 07, 2002 7:54 pm
by QUICKSILVER RACING
I used to have a base program for these. However, I would not recommend using base programs. usually it starts very far from ideal.
I would suggest you start with a stock H058OL program and use the injector sizing info. Then tune it with a wide band.
For me, TUNING B20vtec is not a simple task of copying from the library. Built several of those and each required different fueling and ignition. there are a lot a varying set-ups. like compression, cam, combustion chamber volume as the most obvious.
right..
Posted: Fri Nov 08, 2002 12:57 pm
by no mods
absolutly right.. dyno tuning w/ wide band is only way to do it right.. just hoping that i could get around it casuse im cheap and jobless..
Posted: Fri Nov 08, 2002 6:24 pm
JOBLESS + Hondata Stage4 + wideband O2 = more time to tune.
Posted: Fri Nov 15, 2002 2:31 pm
by no mods
19 credit hours...
Posted: Tue Dec 03, 2002 12:06 am
by hybridsol
Haven't tuned mine yet. Send me an e-mail and I'll give you something to start with....
Sean
Posted: Wed Jan 12, 2005 8:43 am
by djickabod
Im also new to Hondata. I just bought my S200 for a all motor B20vtec. Please let us know what to expect!!! I was told to install the S200 and to Daily drive the car, and not to Dog on it untill I get tuned. Is that true? Please explain that to me.
Posted: Wed Jan 12, 2005 10:22 am
by Super-Tuner
Well, in part throttle your car is in closed loop and trying to adjust for 14.7 a/f according to your 02 feedback so thats probably why they say dont dog it. However if your a/f's are still off you will have bad gas mileage and if you get on it you run a risk of destroying your motor. I would reccomend at least putting a wideband on before even starting the motor
Posted: Wed Jan 12, 2005 1:12 pm
by djickabod
What is and where can I get a Wideband??? Ive only read a lil about it. Im new to all the tunning please explain.
