Hello, I would like to request that we have this feature enabled for this platform.   I have a 2011 2WD, but I'm sure all would enjoy it.  I see when doing a compare from the 2007-2009 RDX that the "Injector flow for fuel economy calc index" was adjusted on the DW 800cc stock equivalent tune.  There are many running the same injectors as I and also the ID 1050X.
Thank you,
Jacob
						Fuel Economy Calculation Enable
Re: Fuel Economy Calculation Enable
Any additional info about this available?94b20gsr wrote: Sun Aug 25, 2019 11:01 am Hello, I would like to request that we have this feature enabled for this platform. I have a 2011 2WD, but I'm sure all would enjoy it. I see when doing a compare from the 2007-2009 RDX that the "Injector flow for fuel economy calc index" was adjusted on the DW 800cc stock equivalent tune. There are many running the same injectors as I and also the ID 1050X.
Thank you,
Jacob
Seems very odd a newer ecu would have less capability. Maybe in the future it can be revisited. Thank you.
