Hi guys
I have hondata S300 v3 on my civic Si 94 with F22 Engine (JDM prelude 92) DOHC 16V non vtec, It is similar to the H23A.
I can't find a basemap for this swap. :-/
Many posts recommends use H22 basemap comes standards calibration in s300 manager for beginng the set up. what is you opinions guys? thanks
F22B or H23A Basemap
G. Wiffington
Re: F22B or H23A Basemap
The H22 maps that come on the basemap file is not gonna work too well for you.
Look around on here for some stock H22 calibrations & upload. MAKE SURE YOU HAVE A WIDEBAND.
Just pull or add fuel where needed. Hook your wideband to the ECU so your computer will see exactly what your wideband is reading.
High fuel tables shouldn't matter since you aren't equipped with VTEC anyway.
Non VTEC engines only use the low cam fuel map & low cam ignition map.
