Lambda Overlay issues after re-install
Posted: Thu Jul 25, 2019 1:03 pm
by Juncura1
KPro Version 4
Serial Number: 41538
Firmware Version: 12.00
Software Version: 4.4.1.0
I recently had to reinstall the KManager software and my lambda overlay is not working. I'm 90% sure that I've replicated the previous settings, but I could be wrong. I've attached my calibration file.
Additionally, I'm using a wideband on ELD0
Re: Lambda Overlay issues after re-install
Posted: Thu Jul 25, 2019 1:30 pm
The calibration has nothing to do with the lambda overlay. Make sure your overlay settings are all being met or it will not display.
Posted: Thu Jul 25, 2019 10:16 pm
by Juncura1
These are my latest settings and they are all being met. Last time, with the previous install, it would only work if I selected "Inches" even though all of my units were set to kPa. However, this time I've tried different settings and none of them have worked. What am I missing?
Posted: Fri Jul 26, 2019 5:57 am
Can you post a datalog as well?
Posted: Mon Jul 29, 2019 12:27 pm
by Juncura1
I got it working using the following settings. It's strange that it only wanted "Inches" when I have all of the units set to kPa (including the the General settings under "Options").
I was also wondering about an issue I'm having with the top of my fuel graph being cutoff. I've tried several "new" calibrations and they all do the same thing. The only way to see the top lines is to 0 out the last cell of the first column. It's not a huge issue, but I thought I'd bring it to your attention.
Posted: Tue Jul 30, 2019 3:18 pm
Fixed for next release. Thank you.
Posted: Tue Jul 30, 2019 3:28 pm
by Juncura1
Hondata wrote: Tue Jul 30, 2019 3:18 pm
Would there be a way to ghost the lambda overlay into the 2d graph so you could see the points and how they would affect the curve?
Posted: Tue Jul 30, 2019 6:20 pm
Not something that's going to happen for the next release, but we will note it down.
