VTEC coming in later than setting
Posted: Mon Jul 08, 2019 9:27 am
Hey guys I just had some questions about the VTEC parameters.
I have read the user guide a few times but it doesn't go too far in detail.
Can someone explain the Upper & Lower Boundary parameters for VTEC?
Does it matter if they are at the same rpm engagement point or should the lower boundary be lower than upper?
Only reason I ask is because I have both points set at 5745 RPM & VTEC seems like it was still only engaging at 5600RPM?
Do you need to raise or lower the setting for kPa or inches? I think right now mine is at 9.0 inches for Lower Boundary & like 21.0 inches for Upper. I am not even sure what that means. I kinda thought at certain throttle percentage VTEC will engage if those parameters are met?
Minimum throttle was set to 45% for engagement.
Sorry, I am at work so I do not have my calibration.
