FK2 Flashpro unreadable error causing 4k rev limit
Posted: Sun Jul 07, 2019 2:50 am
by jessek9
Hi guys,
I have an FK2 that ive been tuning with flashpro, we have hit an issue whereby after an unknown period of time the ecu will trigger an error code and throw the car into a 4000rpm rev limit...The issue being the error code is unreadable, the only thing that will reset the code is a complete reupload of the map file.
It doesnt appear to be cutting any boost just a hard rev limit at 40000rpm.
We have taken a log with the fault present and have the most current map file for the car incase you can see something ive missed.
Re: FK2 Flashpro unreadable error causing 4k rev limit
Posted: Sun Jul 07, 2019 7:10 am
First try using the FlashProManager Diagnostics window to see if there is an error code. If that doesn't work you need to use a scanner to get the error code.
Posted: Mon Jul 08, 2019 1:41 am
by chris2000
jessek9
Where r you located? Did this happened only after you updated your flashpro manager to the newer 3.3.9 version and above?? The next time it happened just try continue to hit the limiter and hold the throttle to see if it will throw a CEL with code P2263 then after the boost will eventually drop to zero.
Hondata/Spunkster
I believe this is the exact issue that we had been communicating with Matt over email with our file and logs last week and we think its a new update file bug. I have since return back to stock and driving for the 4th day with no issues. I'm sure there will be more and more FK2 owners reporting the case onces they update the latest firmware for a retune.
Chris
Posted: Mon Jul 08, 2019 8:45 am
P2263 is probably a symptom not the cause.
Can you use the 'send support information' for one of these vehicles when it has the 4000 rpm limit?
Posted: Tue Jul 09, 2019 6:51 am
by nunoctr
have you tryed with the afm voltage limit disable?
Posted: Tue Jul 09, 2019 10:25 am
by Civicboi_fk2
Hi all,
Im currently experiencing the same 4K rev limit since a Hondata retune. After evaluating a few datalogs the only difference i notice is that on every datalog where i have the problem i have no ABS sensor speed readings whereas when i do not have the fault they are reading correctly.
i notice on the datalog attached to this post the ABS sensors have no reading either. i have attached my datalog where the car worked for 1 day in between faults for reference
Posted: Tue Jul 09, 2019 10:57 am
by jessek9
Flashpro diagnostics read no errors...code scanners dont pick anything up either but the dash has the CEL on and it absolutely will not clear until reupload.
Weve carried this issue through afew different software versions now so i dont think its a new bug. Im pleased that we arent the only guys with this issue tbh as we are at a loss with it.
Posted: Wed Jul 10, 2019 4:32 am
by nunoctr
My friends car, that was mine, also have this problem.
Runs fine for days then hard cut at 4000 rpm. Needs to upload the map again. No cell.
Runs 3.3.7.0 FM so I think the problem started there
Posted: Wed Jul 10, 2019 8:14 am
Do you want it fixed? If so, follow my instructions. If not, keep posting.
Posted: Wed Jul 10, 2019 9:24 am
by chris2000
I had done the send support information earlier with using like stock calibration also triggering the 4k limiter after a day of driving. on version 3.3.9. I believe car was tne previously on 3.2.6 with no rev limiter issues. Thanks Hondata.
Posted: Sat Jul 13, 2019 4:06 am
by jessek9
Hondata wrote: Wed Jul 10, 2019 8:14 am Do you want it fixed? If so, follow my instructions. If not, keep posting.
Unfortunately my guy is 4hours from me, so its alittle difficult to get the info you need quickly.
Hopefully somebody else here can get you the info though.
Thanks for your help.
Posted: Tue Jul 23, 2019 12:28 am
by chris2000
Just an update for all. We have tested for a good 1 week+ and issues had been resolved since the version 3.4.1. Thanks Hondata for sorting it out.
Posted: Tue Jul 23, 2019 5:59 am
Thanks for the feedback. Let us know if the problem occurs again.
Posted: Tue Jul 23, 2019 7:12 am
by chris2000
doing a new jdm fk2r hondata tune next week, hopefully all good by now and just saw a newer 3.4.2 today. hopefully no issues. haha
