Please help load and fuel pressure drop to 0
Posted: Wed Jul 03, 2019 4:51 am
by GangarTypeR
So attached is the graph of what's going on. I believe an injector is not dead timed right (Cheap injectors no flow chart) and its opening or closing at the wrong time and the ecu is trying to adjust the timing thus why its dropping right after. but basically the car sputters out and comes back its pretty much consistent. thanks for any help new to this level of building and tuning
Re: Please help load and fuel pressure drop to 0
Posted: Wed Jul 03, 2019 10:01 am
Without the calibration and the actual Datalog showing the issue it is hard to guess what it might be. A screenshot is not enough.
Posted: Wed Jul 03, 2019 5:31 pm
by GangarTypeR
I can give you the calibration but as for a data log you just want this same chart but the video?
Posted: Fri Jul 05, 2019 9:05 am
I don't want any videos, I just need the recorded Datalog of the issue.
Posted: Sat Jul 20, 2019 9:37 am
by GangarTypeR
so I don't know whats up doesn't seem to be dropping to 0 anymore but i'm so confused got two data logs only difference was getting the tps set correctly on them and also the config here. thanks for any help
Posted: Mon Jul 22, 2019 5:02 pm
What time stamp in the datalog were you experiencing the issue?
