What injector do I use?
Posted: Wed Nov 06, 2002 3:12 pm
My current setup is an 88 crx dx with a 1st gen b16a swapped in it. The motor runs perfect. I had to use the injector resistor box like everyone else does when they do the swap into a dx. Going from dual to multi point fuel injection.
I now have an fmax turbo kit and plan on using the base tune for the b16a turbo in the "tunes library." This base tune uses 440cc injectors. That's the size I want becaus I plan on running bigdick boost later.
My question is do I get "peak and hold" or "saturated" injectors? I have no clue what's in my car right. I'm guessing "peak and hold" because of the resistor box. I need to double check with someone who knows.
