K20 DATALOG
ivanB1
K20 DATALOG
Post by ivanB1 »
Hello, im ivan from argentina and i hope you can check my datalog . i think my A/F is good. between 14.5 14.85 at idle and cruising and some 13.5 at WOT in 3rd gear. I dont know if i should be worry about those knock counts. i just want my car run safe and with good mpg i hope you can analyze my datalog.
Thank you
datalog0000.fpdl
Hpmengine
Re: K20 DATALOG
Post by Hpmengine »
HI
Friend make a better log presented a 3rd fund and 4th fund .... post it and I can help you .... you suffer from a lot of detonations and for my taste 13.5 afr (it's dry)....
Depending on the fuel in your country, spark plugs ...
regards
