Solid Check Engine.
nireus143
Solid Check Engine.
Post by nireus143 »
Zup guys,
I badly need your help regarding my Hondata s300 on P72 Box, solid check engine is on does this mean my hondata chip is busted?
Re: Solid Check Engine.
What does it show in error codes when you Datalog in Smanager?
nireus143
Post by nireus143 »
Only this appears in datalogging. Tuner says that there might be problem on the hondata, but smanagers reads all the chips details and the engine also starts.
nireus143
Post by nireus143 »
Also the chips green light is on and redlight blinking fast
Disable on-board datalogging and check the errors using the datalogging in Smanager.
nireus143
Post by nireus143 »
Sorry for im kinda newbe on this. How can i disable on board dta log?
Also how will i know if my s300 is busted already? Does the below image says my s300 is still ok?
Thnk you for baring with me.
You must disable on-board datalogging within your calibration in the parameters and then reupload the calibration to the ECU.
