Target Lambda Tables
Posted: Fri May 31, 2019 6:45 pm
by web35
I am trying to use the active tuning feature. It appears that your default/preferred method is to use target Lambda tables for open loop situations however the menu for the Lambda tables specifically references closed loop situations. Can you elaborate on this? Are the target lambda tables in the menu the same for closed or open loop?
Re: Target Lambda Tables
Posted: Thu Jun 06, 2019 6:18 pm
by web35
I didn't think this question was so difficult.
To simplify: where/how do I view the open loop Target lambda table in Flashpro for Civic Gen 8 SI?
I have searched and looked everywhere I can think of for 6 days now.
Surely someone out there knows the answer to this basic question.
Posted: Mon Jun 10, 2019 4:17 pm
I don't fully understand the question. What do you mean by 'the menu for the Lambda tables'?
"how do I view the open loop Target lambda table"
In the tables window under 'Target Lambda Low' and 'Target Lambda High'?
Posted: Sat Jun 15, 2019 1:01 pm
by web35
My Tables menu does not have 'Target Lambda' as an option.
Posted: Mon Jun 17, 2019 7:10 am
Are you using mass flow or speed density?
Posted: Mon Jun 17, 2019 8:37 am
by web35
Mass Flow
Posted: Thu Jun 20, 2019 8:56 am
Under mass flow you don't get any active tuning options at all. Can you post the calibration you are using?
