PLX WideBand and Kpro3 issues
Posted: Mon May 20, 2019 1:13 am
Hello all, After searching the forum for a few days about this problem im still none the wiser.
Ive installed the plx which works fine but I can't seem to get the kpro to read anything from the gauge so I can just datalog/tune from it.
I've connected the supplied grey wire from the analog output on the plx to A0 analog *red wire* on the kpro, and earthed the wideband and kpro black wires to the chassis.
Gone into Kmanager and no voltage is being read by the kpro when I open the A0 table even though the red wire is 100% being sent the correct voltage.
The car is a Civic eg running a k20.
After reading Abit of info I've came across a few people using the ELD wire on the kswap harness instead of the supplied analog outputs, should I do that? Even though the ELD is not used on my engine.
Many thanks, Scott
Many thanks, Scott
