AFM and map control air-fuel ratio, which power will be better, thank you
liaoyuan12580
Post by liaoyuan12580 »
AFM and map control air-fuel ratio, which power will be better, thank you.I don't care about fuel consumption.
Re: AFM and map control air-fuel ratio, which power will be better, thank you
The same power. The difference is how easy they are to tune and how close to 0% the fuel trims are.
liaoyuan12580
Hondata wrote: Wed May 15, 2019 9:50 am The same power. The difference is how easy they are to tune and how close to 0% the fuel trims are.
Which is better?
Depends on the vehicle and setup.
