Please explain AFM vs MAP calibrations, and hybrid
Posted: Thu Apr 04, 2019 10:24 am
by spazelite
Hello
I am new to flashpro tuning. After reading the flashpro help and forums, I would really appreciate if someone could give an overview, for those of us who are new, of AFM vs MAP tuning. Also, it looks like historically there were race/MAP tunes but now they are based on AFM with MAP added?
I have started with a calibration based on AFM and only begun to adjust for A/F with the afm.v vs s.trim.
Thanks!
Re: Please explain AFM vs MAP calibrations, and hybrid
Posted: Thu Apr 04, 2019 12:25 pm
Posted: Thu Apr 04, 2019 5:39 pm
by spazelite
Yes, that is a helpful definition. Is there any more detailed information available? For example, I would like to know what happens if I start with a calibration that uses AFM and then click "use MAP" in the calibration settings, will that stop using AFM? Will the maintenance reminders stop working? (like in the race calibrations) And what happens in hybrid AFM/MAP calibrations?
Thanks again for helping a newbie.
Posted: Fri Apr 05, 2019 9:09 am
It will only disable the AFM if you disable it in the calibration. IF the calibration is not a Race calibration then you will not have any issues with the maintenance minders.
Posted: Fri Apr 05, 2019 11:03 am
by spazelite
Thanks! I've also found some posts from 2009 to 2013 on the subject, but that's from older versions. Your information has been very helpful.
Posted: Tue Apr 09, 2019 6:55 pm
by Qyota
What are the reasons NOT to use a MAP-based calibration, if any? Thank you.
Posted: Wed Apr 10, 2019 9:51 am
There is no reason not to
Posted: Wed May 15, 2019 5:37 am
by liaoyuan12580
Spunkster wrote: Wed Apr 10, 2019 9:51 am
Will using AFM get more power?
Posted: Wed May 15, 2019 9:13 am
They should be able to make the same power.
