Unable to set target lambda parameters on version 2.6.9.0
Posted: Wed Apr 03, 2019 8:16 pm
by nickman
Installed latest version today and I noticed I'm unable to set lambda parameters base on engine load. I'm on windows 10
Re: Unable to set target lambda parameters on version 2.6.9.0
Posted: Wed Apr 03, 2019 11:39 pm
Fixed in v2.7.0
Posted: Thu Apr 04, 2019 6:03 am
by nickman
Sweet thanks!
Posted: Thu Apr 04, 2019 9:11 am
by nickman
Hondata wrote: Wed Apr 03, 2019 11:39 pmFixed in v2.7.0
Since the update to 2.7 I got a couple of problems.
I am to connect to the ECU and download the basemap. But when I attempt to datalog it gives an error and automatically closes the application.
I also notice that if I don't download the basemap on the ecu it connects to datalog and when I attempt to download the basemap while datalogged it gives the same error
Also this maybe minor but on column 10 on the fuel map no matter if I change it to vacuum or psi its value is not right.
Posted: Thu Apr 04, 2019 9:21 am
What s300 do you have, and what are you doing then you 'download the basemap'?
Posted: Thu Apr 04, 2019 9:38 am
Ok, I've got it. You need to go into settings and set the datalog overlay sensor to something. I think the lambda sensor might still be a problem for you (if it does not say 'AF'), but I'll make a new release shortly that will take care of it.
Posted: Thu Apr 04, 2019 10:07 am
by nickman
Hondata wrote: Thu Apr 04, 2019 9:21 am
I am running S300 V3. I go under the "online" tab and click download when I'm connected to my ECU to download the current tune.
Posted: Thu Apr 04, 2019 10:13 am
by nickman
On version 2.6.8 I didn't have this problem
Posted: Thu Apr 04, 2019 12:09 pm
Try 2.7.1
