Unable to set target lambda parameters on version 2.6.9.0
Installed latest version today and I noticed I'm unable to set lambda parameters base on engine load. I'm on windows 10
Re: Unable to set target lambda parameters on version 2.6.9.0
Since the update to 2.7 I got a couple of problems.
I am to connect to the ECU and download the basemap. But when I attempt to datalog it gives an error and automatically closes the application.
I also notice that if I don't download the basemap on the ecu it connects to datalog and when I attempt to download the basemap while datalogged it gives the same error
Also this maybe minor but on column 10 on the fuel map no matter if I change it to vacuum or psi its value is not right.
What s300 do you have, and what are you doing then you 'download the basemap'?
Ok, I've got it. You need to go into settings and set the datalog overlay sensor to something. I think the lambda sensor might still be a problem for you (if it does not say 'AF'), but I'll make a new release shortly that will take care of it.
I am running S300 V3. I go under the "online" tab and click download when I'm connected to my ECU to download the current tune.Hondata wrote: Thu Apr 04, 2019 9:21 am What s300 do you have, and what are you doing then you 'download the basemap'?
On version 2.6.8 I didn't have this problem
