Flashpro Manager 3.2.8.0 version box error
Rush
Post by Rush »
Flashpro seems to have a conflict with the current 3.2.8.0 Manager. Tune seems to have loaded correctly.
Re: Flashpro Manager 3.2.8.0 version box error
Are you getting this message after you have uploaded to the ECU using 3.2.8 software?
Rush
Post by Rush »
It happens when I connect the Flashpro to the computer. The Flashpro had the tune loaded on 3.2.8.0. I deleted the tune and reloaded 3 times to the Flashpro and same box appears each time.
But did you actually upload the calibration to the ECU?
Rush
Post by Rush »
Yes. It took 2 tries. First had an engine light emission code. Second try all went well, no errors.
And it is telling you the calibration is still out of date after uploading to the ECU now?
Rush
Post by Rush »
Correct. Each time I connect the Flashpro to the Manager the box appears.
nappco
Post by nappco »
....2018 Hatch MT
I have the same message. It started for me when I updated a few weeks or so with version 3.2.6. I hadn't touched it or reflashed since last summer. I also had an update error that reported with 3.2.6 when I was flashing the ECU... about 1/4 into the flash it said there was an error, then after a min it started reloading again.I think the upload didn't take. The Hondata Mode seemed to be stock tuning. I have no screen shots.
I updated with 3.2.8.0 last night and haven't had a chance to see if the tune is good.
nappco
Post by nappco »
Well, I think there is a firmware problem. I flashed my original tune and its still not correct. I've attached the tune from July 2018. I think there is a problem with either the traction control or boost by gear. Hope this helps
The message 'Calibrations stored on the FlashPro are from a previous ...' is normal after an update.
nappco
Post by nappco »
Thanks, any thoughts on the update? There was a major downgrade in performance after this update.
nappco
Post by nappco »
I put the factory tune back in and verified the new version is not working correctly. There is no difference in performance.
