Acuity Curl Control CAI MAP PLEASE
natas666
Post by natas666 »
My last car was totaled and I’m starting over from scratch. I just bought The Acuity Curl-Control CAI and it is 3.5 inches at The MAF. Acuity suggested not to use the base tuning map. Everything else in the car is stock. I’m looking for a good tune to fit this intake to get started. Then, I can drop thousands of more dollars into my car like a fool. Thanks for any help.
Re: Acuity Curl Control CAI MAP PLEASE
This will require custom AFM tuning on the dyno to get it to run safely and correctly.
natas666
Post by natas666 »
Right on. I appreciate you. Do you know or suggest any place in the Seattle area?
Any of the dealers listed at https://www.hondata.com/us-dealers should be able to assist you with this.
gtfrede07
Post by gtfrede07 »
I just did cal yesterday on a 2015 for a guy that put this on and it wouldn't run at all. He was stranded at his job after install because he was unaware of the consequences. Took all of 20 minutes street tuning it. The trims were off the charts maxed and it barely stayed running.
He's out ripping in it now.
