Radio Interference from S300
kraquepype
Post by kraquepype »
Hello,
Ever since I installed my ECU w/S300v3, I get radio interfererence while the ECU is on. Is this normal, and has anyone else experienced it?
It is worse with the USB cable plugged in, but still noticeable with it unplugged.
1989 Civic Si, D16A6 with Hondata S300v3
Re: Radio Interference from S300
Check all grounds in the engine bay and the ground under the seat.
kraquepype
Thanks, I checked the engine grounds. I was missing the chassis to trans ground and valve cover, I ran those and the car is running better but still get static.
Under which seat?
