Dc5 turbo hesitation, bogging, misfire
Posted: Tue Mar 19, 2019 2:29 pm
Hi guys been having an issue recently with my dc5 turbo that I'm struggling to get to the bottom of. The problem is from tip in upto about 25% throttle the car is bogging really bad, give it more throttle then the car jerks and drive fine. Looking back at the data log the ignition goes crazy when this happens which would point to a faulty TPS but replaced it with an acuity hall effect tps and scaled it in kmanager, the problem dissappeared for a day or so then returned. I then put the 'tip in ignition retard' to - 100 which has helped when the engine is hot but the problem still remains when the car is cold and I'd say its getting worse.
The car has been tuned and ran perfectly up until this new problem.
Probably just a coincidence but at the time this problem started my iacv jammed closed and wouldn't idle, I removed, cleaned and lubed it and it was freely spinning. It's idling perfect now with no issues so doubt it has anything to do with the problem.
Going to have a look at the connector and wiring tommorow to see if there's any issues there.
Anyone have any ideas? And does anyone know what would cause tps 'noise' on a brand new sensor??
