07 Basemap
Posted: Sat Mar 09, 2019 4:16 pm
by bdy099
Currently have a full bolt on FG2 and am running the skunk2 catback, header, CAI basemap.
Mods:
Skunk2 Alpha
Q300
Injen CAI
If someone has a similar setup and has a decent map I would like to try it out. I live in Arizona as well so cold weather people probably should not link tunes. Thanks
Re: 07 Basemap
Posted: Sat Mar 09, 2019 6:28 pm
by EFICU
PM sent.
Re: 07 Basemap
Posted: Tue Mar 12, 2019 1:50 pm
by bdy099
can't use pms right now this is a new account as I lost my old login info. I am running a base map. actually knock sensor just started going off 2 days ago and I have been scared to drive the thing. I get some sort of rattle/metallic sound from the driver side of the engine bay when im in gear and around 2.8k and 3.2k rpm, it will flash the programmed cel knock sensor and then go away once im past the rpm range. only happens when more than 30-40% throttle and happens in lower gears only. I might of put 87 in it but im not totally sure cause that would be a first for me. Tank is about half gone.
Re: 07 Basemap
Posted: Wed Mar 13, 2019 8:53 pm
by EFICU
Okay. What email address can I reach you at?
