07 Si Basemap Lean at WOT
Posted: Mon Mar 04, 2019 5:47 pm
by alarose64
Hi all. I recently got flashpro for my 07 Si with a K&N SRI and Vibrant exhaust. I flashed the K&N SRI MAP based tune and did a few WOT pulls and noticed it is running a bit lean. From the datalog attached, it seems like it is high 13s at WOT with jumps to 14 A/F. I have tried using the stock, tuned basemap and have the same problem. On this particular log, I got no knocks and the car feels a lot peppier than bone stock, but I am worried about high cylinder temperatures leading to long term damage.
Can someone take a look at the log and tell me if everything looks okay, or if it is in fact running an unsafe A/F?
K&N SRI MAP based.fpdl
Re: 07 Si Basemap Lean at WOT
Posted: Tue Mar 05, 2019 1:12 am
by EFICU
Hi,
Yes it is too lean in the wide open throttle areas. If you'd like I can help you richen it up and dial it in better if you send me the file you're running on.
Posted: Wed Mar 06, 2019 3:44 pm
by alarose64
Thanks man. Here is the basemap I was using.
Posted: Thu Mar 07, 2019 1:12 am
by EFICU
alarose64 wrote: Wed Mar 06, 2019 3:44 pm Thanks man. Here is the basemap I was using.
Check your PM's.
Posted: Sat Mar 23, 2019 8:57 am
by GhostGreyFg2
Try this Basemap
